Zeiss Cinemizer Goggles In Stock
Jacksonville, FL
www.builtdrones.com
$719.99 - We will match/beat pricing.
http://www.uav-outlet.com/products/zeiss-cinemizer-oled-glasses.html
Product Highlights
  • Up To 6 Hours Battery Life
  • -5 to +2 Diopter Adjustment
  • Soft Silicon Nose Pads for Added Comfort
  • iPod / iPhone Connectivity
  • HDMI / AV Interface
  • Rich Colors
  • 3D Support
Cinemizer OLED Product Information
Technical Details:
Display:
  • two high-resolution OLED displays (Organic Light Emitting Diode)
  • each with 870 × 500 pixels and a fill factor of 100%
  • Simulated image size: 40 inch (= 1 m) at a distance of 2 meters
  • Aspect ratio: 16:9
  • Color depth: 24 Bit RGB
  • FoV (Field of View): 30°
3D-Support:
  • Side-by-side/Top-Bottom/Line interleaved
  • Frame Packing with HDMI 1.4 (720p/1080p)
  • NVIDIA 3DTV PlayTM supports the cinemizer OLED as a 3D display unit
Diopter range:
  • Both sides separately adjustable between -5 and +2 diopters
Interpupillary distance:
  • The optics support an interpupillary distances (IPD) between 59 and 69 mm
Content feed:
  • HDMI: 640x480p 60Hz, 720x576p 50Hz, 720x480p 60Hz, 1280x720p 50/60Hz, 1920x1080i 50/60Hz, 1920x1080p 50/60Hz, 1920x1080p 24Hz, HDMI 1.4 3D 1080p 24 Hz, HDMI 1.4 3D 720p 60Hz
  • iPod/iPhone: iPod and iPhone models with video capability via optional accessories
  • AV-In: 3.5 mm/4-pin connector for audio & video (PAL/NTSC)
External connectors:
  • Mini-USB to charge the integrated battery
  • 3.5 mm audio port for external stereo headphones
Audio:
  • Stereo sound
light source:
  • Class 1 LED
Power supply/battery:
  • Rechargeable lithium-ion battery
  • Charge via USB
  • Voltage: 5 V
  • Power supply: 450 mA
  • Battery life: up to 6 hours for iPod/iPhone and AV-In and up to 2.5 hours for HDMI
  • Charging time: approx. 2.5 hours
Weight & Size:
  • Battery unit: 60 g
  • HDMI adapter: 30g
  • Weight on nose: approx. 75 g
  • Total weight of the video glasses: 120 g
  • Total weight (including packaging): 800 g
  • Package size (W × H × D): 230 mm × 180 mm × 80 mm
Ambient conditions:
  • Operation: from 5 °C to 35 °C
  • Transportation and storage: from -20 °C to 45 °C
  • Humidity: 10% to 80%, non-condensing
Scope of delivery:
EAN code
  • 4047865190220
Country approvals:
  • Europe, including Switzerland Australia Brazil China India Japan Canada Mexico Russia Singapore Turkey UAE USA
alishatomar
