Zenmuse X5 Polarising Filter Basics Help
Hi there!
I'm new to this, and i have to learn a lot. I have a polirising filter for my Zenmuse X5. The thing is how do you adjust rotation while in flight?!?! a mean thats obviously not possible, so how do you deal with that to get the filter work without being able to rotate it while in flight!?? How or in which position do you preset the filter?
So what you have to do is point the camera to where you will be shooting (while in your hands/ground), then rotate the CPL filter until you get what you are after in the colours. CPL are good for removing reflections from water, glass or other shiny surfaces like car paint.
While rotating, your should see some slight change in glare and the sky will turn darker/blue. Once you're happy with that, you fly with that setup.
Reactions: EDDSkitz
HawaiiProSounDvr
