When using gps tracker there's no range limit as long as you're in cellular coverage area. .what device do you use to find the lost inspire and what range do you think it will work at
not really what I meant ,I know its value that value I need to know where it can be purchased from and how much
Thanks for pointing that out,but I'm not sure what you mean by the zip tie interfering with the spool mechanism. .I noticed your GetterBack. I would remove the zip tie. In your configuration, the "spool" will not eject. If you feel the need to secure the device, zip tie the velcro side.
Just my two cents.
Hey thanks for pointing that out!!!! That's really cool!!Oh sure.
This is what it looks like when the unit is activated:
So in your picture, the zip tie prevents the top part of the GetterBack from popping off if it ever gets wet.
Here's a video of it in action:
I've seen the video a while back and didn't realize how it worked. .
as I'm sure you figured out I thought the top came off and floated up to the top not the bottom portion of the device. .
thanks again
turbo. .
Very Cool! Now I need to print up a holder for my Trackimo. I have it velcro'ed on the rear of the craft but love the idea of it on the arms.Problem solved. .good looking out.. View attachment 703
Ive used them and they work!
This was a poor ads 400q frame which crashed into the lake. Recovered and everything but 1 esc and the go pro survived. The go pro actually worked, but the lens go mucked up, go pro was kind enough to replace it at cost pricing.
Thanks for sharing! ! I got all happy when you pulled it out of the water.. pretty cool.. definitely worth the 15 bucks..
turbo. .
Good advice. .why not put two getter backs on board. .they're only 15 dollars. .I personally put 2 on mine. one at the front left left and one on the rear left leg. I would be worried if the quad hit the water and sank up side down then 1 might get stuck in muck or something. Ive also experiences only 1 releasing (not sure what happened) but I will awlays fly with 2
Blade, I'm very interested in acquiring one of these for the Trackimo. If you are willing to sell one, please let me know and I'll gladly Ppal you the funds to make it happen. Thanks.I could do that.. I will be making one for the trackimo and similar sized devices.
