I am using the DJI XT infrared camera 640x512. Has anyone used this camera with pix4d, maps made easy, or drone deploy? Was wondering about signal strength, range, ect.
From what I have found is that pix4d is the best, although not the easiest to use. It is also only compatible with the high resolution DJI XT camera.
Reactions: leeSenes
So you use autopilot app and drop those pics into pix4D?
It allows you to stitch?
That is the plan. I have a workstation coming and i will be trying them in Pix4d in coming weeks. I will post with results.
What i am worry about is the erroneous altitude readings in the EXTIF data. When flying below 100' they are not accurate.
istore
