Firmware V01.08.01.00 required
This is a GREAT Charles Proxy tutorial. Worth noting, you're going to need an old version of iTunes on a Windows PC. The version I use is 12.5.4.42, which is really the best version for hacking.
Alsp worth noting, those numbers are called the "Software Version External Identifiers." You can see this in the video:
Also worth noting, instead of exporting the .xml file (which isn't a bad idea at all), you can click the "Summary" tab and then the "XML" tab at the bottom of the page to see the same thing in real-time that the export file would show you.
Thanks for the info!
Dear colleagues or anyone knows which old firmware version works with AF in lenses that were not supported by DJI (Olympus 35-100 or Olympus 14-42 and similar to Panasonic 45-176). Unfortunately, the latest software does not support AF but also makes huge problems with manual focus. I am desperate and I would like to revert the drone's software to some version that works with AF in these unusual lenses
I'm in the process of rolling back my I1V2 firmware to V01.08.01.00. The I1V2 is used with both the the X3 and X5 cameras. I use the X3 camera exclusively for the firmware flashes as there seems to be issues at times using the X5 camera for this.
The aircraft FW was on the latest when I started. So this has been my progression: WM610_FW_V01.11.01.50+ -> WM610_FW_V01.10.01.40 -> WM610_FW_V01.09.01.30 and the FW the aircarft is on right now is v1.9.1.30 as from the Go app. I'm trying to roll back to V01.08.01.00, but I keep on getting stuck on the downgrade from WM610_FW_V01.09.01.30 -> WM610_FW_V01.08.01.00.
I've tried the DEBUG file, I've tried forcing the firmware flash with the red bind button, which have worked with all other firmware flashes, just not this one. All I can think is that the WM610_FW_V01.08.01.00.bin files I have been able to get are somehow damaged.
I've tried files from:
Of course DJI no longer publicly hosts this bin file for the Inspire 1, so I can't get it there either.
I'm appealing to the community here, to someone who has an original WM610_FW_V01.08.01.00.bin file that they know is working fine (have flashed it to their aircraft without issues of any kind) to kindly PM me a link to a WeTransfer / DropBox or similar link where I can download this.
Appreciated!
I have a modded version with hight limits removed and nfz removed and speed increased
Reactions: An7on
¡Éxito! ¡Actualizado a WM610_FW_V01.08.01.00!
Gracias por la ayuda con la gente de archivos bin.
hola amigo disculpa que te moleste.. seguí todos sus pasos. Y el drone quedó haciendo tipido en los motores. Alguien sabe como salvarlo ?? Te paso algo parecido?
Hola Donnie, ya hemos analizado esto por mensaje privado antes. Sin embargo, para beneficio del foro (y, con suerte, para mí), lo repasaré nuevamente.
  • Avión (Inspire 1 V2) apagado. Controlador y iPad apagados.
  • Batería del avión llena. No he intentado flashear FW con la batería al 50% de carga o menos.
  • Tarjeta MicroSD en el Adaptador MicroSD (formateada previamente por el avión) en la PC.
  • Copie el archivo WM610_FW_DEBUG a la tarjeta SD. (Los archivos de depuración denominados WM610_FC350_FW_DEBUG o WM610_FC550_FW_DEBUG no funcionan).
  • Copie el archivo .bin a la tarjeta SD. El archivo FW debe llamarse INMCAPPFw1.bin para funcionar. Los archivos FW nombrados en formato (ejemplos a continuación para la versión v1.11) WM610_FW_V01.11.01.50.bin también funcionan. Los archivos FW nombrados en el formato WM610_FC350_FW_V01.11.01.50.bin o WM610_FC550_FW_V01.11.01.50.bin no funcionan para actualizar a la versión v1.11 (por ejemplo).
  • Comando de expulsión en la PC para el adaptador MicroSD con tarjeta MicroSD, saque la tarjeta.
  • Inserte la tarjeta Micro SD en la ranura para tarjetas Micro SD del Zenmuse X3.
  • Busque el botón de vinculación, presione y mantenga presionado el botón de vinculación.
  • Toque dos veces la batería para iniciar el avión, manteniendo presionado el botón de vinculación.
  • Suelte el botón de vinculación una vez que escuche el sonido DDDD.
  • Dejo que el proceso de flasheo se ejecute hasta que escuche el sonido D-DD repetido, lo dejo funcionar durante unos minutos (aprox. 2-3 min.) más.
  • Toca dos veces la batería para apagar el avión.
  • Retire la tarjeta Micro SD de la cámara Zenmuse X3 y colóquela en el adaptador Micro SD.
  • Verifique la tarjeta SD en la PC. La mayoría de las veces, el archivo de registro no dice "éxito" a pesar de que el proceso ha finalizado (sonido D-DD) y la versión en la aplicación Go indica que el flash FW se realizó correctamente. (Esta es mi experiencia al cambiar a v1.10 desde v1.11+).
Lo anterior funcionó al actualizar el firmware WM610_FW_V01.11.01.50+ / WM610_FW_V01.10.01.40 / WM610_FW_V01.09.01.30 pero no funcionará para el firmware WM610_FW_V01.08.01.00.
Intenté usar múltiples configuraciones de nombres de archivos de depuración y nombres de archivos FW, solo funciona como se indicó anteriormente.
Intenté actualizar el firmware WM610_FW_V01.08.01.00 sin mantener presionado el botón de vinculación rojo (confiando solo en el archivo DEBUG), pero tampoco funciona. Prefiero usar el método del botón de enlace rojo, ya que ahorra tiempo al tener que rehacer algunos pasos si el intento de flashear no funciona por algún motivo. La tasa de éxito con el botón de enlace rojo es muy alta al actualizar o degradar el firmware (aparte del firmware WM610_FW_V01.08.01.00).
Intenté dejar que el firmware WM610_FW_V01.08.01.00 se "cocine" durante 40 minutos (podría haber sido un poco más, definitivamente no más corto), no termina, sigue emitiendo un sonido sin cambios una vez que comienza el proceso. Vea el archivo ZIP adjunto para ver un clip MP4 de 10 segundos sobre el sonido de la aeronave durante el flasheo con el firmware WM610_FW_V01.08.01.00. Disculpas por la calidad del sonido, suba el sonido para escuchar claramente lo que está haciendo la aeronave. El gemido del X3 tiene un tono más alto de lo normal y no tiene interrupciones, es como si el ventilador del X3 estuviera funcionando a todo trapo. Afortunadamente estos flashes erróneos del FW no han bloqueado el avión ni han dañado el X3, pero no quiero tentar a la suerte...
Alguna información adicional, si es importante:
  • Ir a la versión 3.1.64 de la aplicación
  • Versión del controlador 1.7.80
Ni la aplicación Go ni el controlador se encienden durante la operación de actualización del firmware.
Steve Barnes también sugirió que pusiera a disposición el siguiente archivo LOG.TXT, pero aún no ha comentado al respecto (hilo de Facebook DJI Modding Lounge). Así que si sabes leer esto, ¡bien por ti! ¡Por favor ilumínanos!
Entonces, si alguien tiene una idea o puede ayudar, no dude en comentar.
hola amigo disculpa que te moleste.. seguí todos sus pasos al momento de actualizarlo. Y el drone quedó haciendo tipido en los motores. Alguien sabe como salvarlo?? ¿Te paso algo parecido?
When I downgraded my inspires from fw 1.11 to fw 1.08 I didn't do the inbetween fw's I went straight to fw 1.08 with the magic debug file and it worked fine for the x3, z3 and x5 cameras
Are u still on here mate can u message me the step by step information so I can wrap my head around
do u still have the v1.08 file as i cant seem to find it anywhwere
Hi,
i am too searching for a v1.08 x3 panobot version to downgrade (not the version from the dji site)
if anyone could send me one that would be great.
kind regards
Gunnar
AdolphBonn
