Inspire 1 | Landing Gear Antenna
I have an Inspire 1 drone, and the landing gear antenna split in half; I managed to repair it, but I am not sure how well it will hold up when it gets going.
So! I was wondering if anyone knew of a more permanent fix for it. Will any antenna do? Does it have its own propriety wireless jack? How long does the cable have to be?
Any advice on replacing the wireless cable; even if I have to solder it, and links to relevant replacement materials would be a Godsend.
I found these, but I am uncertain if they will be long enough to run through the tubing. I also found these on eBay, but again, uncertain as I can't find any good reference material on Inspire 1 repairs.
Pictures of what you’re dealing with?
Which side has the problem?
Back right, I may have found a replacement and spent a night studying what type of coaxial it uses. I may just do a complete splice depending on how flight tests go today.
familyphotoshoot
