Panorama/stitch workflow? Heavy vignette on my XT!
Hi guys,
I've been trying to create stitched images with my zenmuse XT but due to there being quite a heavy vignette around my image I've been having a lot of trouble.
What are your workflows for making panorama/ stitched images?
I know with gimbal heat and other factors there will always be some vignette, but should it be kept to a minimum? Mine takes up about a quarter of the image from each side.
Thanks, any pointers would be helpful.
Which app did you use for stitching? Upload one set of pano images I can give it a try.
Hey!
Thank you so much for offering to take a look at this for me. Here is a link to a folder of images i took. Please can you let me know if you think anything is wrong or anything i can do better.
Gaps between stitches are shown by images taken straight down.
Reactions: CoreySnipes
Hey!
Just eyeballing the photo set, I think you may not have enough overlap in your images, so the software may be struggling to find common points in the photos. That is, you might need to take photos more often as you orbit the building. I'm going to see if I can run these through OpenDroneMap, but first wanted to mention that observation while I was thinking about it.
OK, yeah, ODM is Structure From Motion / Photogrammetry (not stitching) so this isn't really what you were asking for. However I tried running it anyway, and the tool wasn't able to accomplish anything useful.
My recommendation (which would also improve your results in stitching) is to re-fly, and take a lot more photos. Increasing your overlap will give you a lot more common points between your photos, which will help the software.
Hey,
Thanks for taking a look. Instead of creating a 3D model from a full orbit I was just hoping to use multiple pictures to generate higher resolution images from the two corners, sorry i didn't really state too much!
My current workflow has been editing them in a batch to a color pallette, tuning the scale and then using Microsoft Image Editor to assemble them. However there seems to be a large vignette on the pictures when I'm tuning so its been difficult to do it well.
Is there a chance too much overlap may ruin may cause inaccurate thermal data?
Hey,
Ah, OK - I see what you're trying to do. Sorry, I don't really have much knowledge or experience in that area.
Sorry for the late reply, my Win10 PC died after a recent auto update and I just revived it today.
I gave it quick go in Gigapano 4.4.2, not great but I got something. It automatically detected 2 groups and did the stitching based on that.
So I guess you didn't use any tool to take the sequence, just eyeballed it? I'm sure there are something out there you can programmatically take the sequence with desired overlap. Maybe the HDRPano app (link below). Unfortunately I'm not familiar with XT.
EDIT: this app may not support Inspire 1. Double check first.
AdolphBonn
