DJI Inspire Battery Mod
Yes. Or use 1 x 6s in parallel. You really don't want to connect a 3s to a 6s! Big sparks and possibly fire, not a good thing.
thanks. :) 2x3s in series it is. As I posted before, I'm getting okay times with the 2x 1300s but more is merrier.
Just dont over do it with the mah and weight and make sure that your batteries are LIHV and not the normal Lipo batteries.....
I did my mod on one of my inspires......now I am set up to add two batteries.
What are the best two to use? weight? vs Price?
I do not want to wire in parallel, I just want to put a battery on each side as I have a t60 connector on each side,wired to the board not battery.
I will use a 48 as well.
Thanks for your ideas.
Because your original battery is like that and must be the same .....
Said that i am not an expert but i read the post about battery mod and the
people there suggest them...
Here is the link .... I suggest you if you are interested in doing this to read it from the beggining it has a lot of valuable info all over the place...
Battery Mod Info
PalmaNewki
