Ipad mini 3 with Wifi only with Pilot
But using my iPhone as my display leaving cellular is OK? Or is it more advisable to let maps load then switch into airplane mode?
Also how much data does the map load pre take of? (Radius of map data)
Guys,
If you want a safe way to connect, as well as having generally a better signal quality and using only the wifi option on you device get a mifi unit
I've had my mifi unit for years and it can connect up to 5 devices onto wifi... It's the size of a box of matches and I use throwaway 3gb SIM cards so I don't sign up to a service provider.
Not sure how they work in the USA but over here in the UK it's brilliant.... And for this activity, absolutely perfect...
Abdul-Majid
