4K test first time with X5s
This is for just checking first time raw
Need recommendations for LUT for the X5s
Nice, what lens in the second shot? What do you use for the raw video process?
I've been using pro-res, seems pretty good, and premiere handles it well.
Hi
That was just a test
From what I've tested it seems like even in 5.2K monitor almost cannot see any difference, I probably will use ProRes
The raw just gives a lot of play in color range.
I'm using here the 15mm lens
Also tried with 25mm and 45mm
I'm using Final Cut Pro which I'm not sure that it's the right software to process RAW
Anyway I'm still doing a lot of test since raw is new to me and I'm not a professional person...
After 1 month I'm still not happy with the results and probably I will need a lot of practice...
Moshe
BTW
can you upload somewhere the original files you shoot?
I want to compare something
(I suspect something is not perfect with my camera)
My forage doesn't looks so smooth as your...
Trezoriostat
