Balance Ring Questions- X5S - 45mm & 9 - 18MM
two are used so you have flexibility in the configuration depending on weight filter you may use. If not using a filter, use two, if using a filter, use only one ring... as an example.
Reactions: dkotinsky
Question: Does the X5S come with these two rings for the 45mm in its box?
The way I read it is the 45mm lens comes with the rings in its 45mm lens package, but I don't think Olympus includes those rings, correct? Different 45mm lens?
Thx.
Gaitandudek
