Battery spring broken help
Anyone knows a good YT tutorial how to fix the broken spring which pushes the battery out after pressing the battery release button?
I believe a stuck battery button and battery spring issue are basically the same problem. There are several threads on this subject already.
This thread (post #10) will probably answer your question as to a 'repair' or what you will need to remedy the issue.
That is not the problem I have. My problem is the broken spring loaded tab which ejects the battery out of the connector after pressing the concentric battery release buttons. It is not really a big deal, I just have to pull the battery out while holding the button down.
The Inspire 1 doesn't have a spring release mechanism for the battery. So there's nothing wrong with your bird.
Udaipurescort66
