Break in batteries
Probably a stupid question... but should you break in the Inspire 2 batteries, I.e. Not run below 50% or sustained high speed for the first few usages. I've seen various posts mentioning this, but not seen anything in the manaual (may have missed it).
Thanks.
Reactions: Phil DeVore
Thanks.
Not that I’m aware of. I’ve got 12 TB50 batteries and I didn’t worry about breaking them in and a couple are from 2017 when I originally bought my I2.
Thanks.
It's funny how much mystery our LiPo batteries are nestled in. As a guy who has owned, used and maintained dozens of LiPo batteries over a period of many years and many flights, I can say with a lot of confidence that longevity and reliability lie with how you store them, not so much how you use them. I have batteries still in service with over 100 flights on them. Conversely, I've had batteries fail in < 30 flights. Both are my fault. The age-old practice of tossing batteries into a closet and forgetting about them is the bane of their existence. That said...
I know this doesn't directly answer your question, but I'll share this information anyway. My experience has been that 60%-70% (third blinking LED) is the best storage capacity. I have P4P batteries still in service with over 100 flights on them. Conversely, I forgot about my Mavic Pro batteries and sure enough, one of them is now dead, dead, dead after only 30-something flights on it.
Common sense dictates that a gentle break-in is probably better for a LiPo than running it hard out of the box. But there is zero data to support this (at least I can't find any). So, we should entertain the possibility that the opposite could be true. So, I say just use 'em normally, but make sure you store them correctly.
Another "best practice" is to not allow them to drop below 30% capacity. 90% of my flights fall into this category. About half of my flights I'll change the battery @ 50%.
If you have a two-battery mission, it makes more sense to divide the wear evenly between the two batteries than to drop one to 20% and the other to 90%. Dropping both to 50% means a short, 5-10 minute charge will bring them up to the sweet 60-70% storage capacity.
Another best practice is to fully drain the battery down to 0% capacity (which is NOT 0 volts), and then fully charge it every 10 flights.
Following these best practices should allow your batteries to last many years.
This is why it never works for a company to purchase a drone. They never delegate drone stewardship to any specific person, so the drone loses its luster, gets tossed in a closet and everyone is shocked when the batteries are dead and won't accept a charge a year later.
Good luck!
customcanabis1
