Camera controls changed?
Guys I haven't flow my inspire one in a while but I used to be able to control the camera with the wheels on the remote, left was up and down and right was left and right. How I can't do that anymore, has this changed?
I had having to switch with C1/C2 between one or the other I want to have the same controls I had before, is this due to a new firmware? Is there a way to change it back?
When i try the right wheel it wants to change the camera exposure setting, I am confused.
Thanks,
Adrian
Go to RC settings and change the various parameters for the two buttons. I think it is better to be connected to the aircraft to see everything is working as it should especially pan speed.
Thanks,
Adrian
The right wheel has never controlled gimbal movement.
The reason being it is notched and moves in increments - this would be useless for gimbal control.
DJI have never implemented any kind of gimbal movement on the right wheel other than correction of the roll axis to straighten up horizon drift but this necessitates holding C2 at the same time
You must be remembering wrong, C1/C2 was needed to switch the left wheel between up/down and left/right from day one.
