Controlling x5s on Inspire 2
Not sure off the top of my head if you can program the left one. they call the triggers C2/C1
Going with what u said if i hold the C1 button in an turn left wheel it gives me the 360 degree turning, if i hold the C2 Button in an turn wheel it moves the other camera up an down
Thank you for your help much appreciated
Also, press and hold on your Ipad/Android screen you are flying with, a blue circle will appear and move your finger to where you want the camera to look.
Reactions: deltalimatango
if you turn the left wheel without holding a trigger it rotates the camera vertically, up and down.
if you hold the left trigger while turning the left wheel it rotates the camera horizontally, left/right.
or as @r62ewa said in the earlier post you can press and hold to move the camera with the screen of your device.
Reactions: Paul Nordin
[QUOTE="PatrickP, post: 165589, member: 35291"... rotates the camera vertically, up and down.
...rotates the camera horizontally, left/right.
[/QUOTE]
Friendly point of clarification. In camera / cinematography worlds that is commonly called: Tilt, and Pan respectively.
Reactions: Advexure
ziamedicalcenter
