Crystal Sky Keyboard Phantom Strokes and No Backspace
Mississauga Ontario Canada
www.skyproimages.com
When trying to download maps for offline use there is a prompt where you can name the map region. When I try to do that the phantom letters appear. In the screenshot below I only typed the word "Port" but you can see what appeared.
Additionally I am not able to use the backspace key, if just doesn't work.
Any help would be appreciated!!
Hi Snowbird,
This is a known issue, the current workaround is to press the backspace key after you type each letter, for instance, if you want to type “port” you would type “p backspace o backspace r backspace t backspace”. Give it a try, should work.
Mark
Reactions: Snowbird and Ranvan
ziamedicalcenter
