Final Cut Pro X Basics: Editing using musical peaks and beats to add emphasis
Portland, OR
www.portlandprodrones.com
This is an article I wrote for Photofocus.com. I hope this is helpful.
In this video, using Final Cut Pro X, I’m going to show you how to take a piece of music and using markers, to position the clips to the peaks or places of emphasis in the music, so that the transition between clips has more impact. In addition, I’ll add what is called a connected clip, a clip that isn’t connected to the storyline but connected to another clip, so we can position the clip with greater freedom.
I will also take a clip and do what is called Lift from Storyline, because the music I will be using will be attached to that clip in the storyline and we want to move it to a different starting position. I will use the Trim tool to change what shows at a clip’s starting and ending points without changing the duration of the clip.
You'll find the full article here:
Final Cut Pro X Basics: Editing using musical peaks and beats to add emphasis | Photofocus
StacyD8952
