Finger Pan (FP)
Ohio
Is there a particular setting that finger panning works in? or doesn't? I could swear I've used this feature before, but cannot get it to work. I have the drone on a table (no props), so I can tweak the settings for a job tomorrow, but FP is not working. The gimbal is in free mode. It's raining right now, so I can't determine whether the aircraft needs to be in flight or not.
Doesn’t have to be flying, hold your finger on the screen till the circle shows up then move.
Make sure the gimbal is in free mode, when it can be controlled with the left dial while holding the c2, (I believe) right side button. If you have a second controller set it up as a slave, retain gimbal control, finger control should work.
Reactions: Phillip DeVore
myoxfordtyres
