Flights over 400 Ft. AGL
Does anyone know how to override the lastest firmware (DJI Go 4 - I2) limit to go above ground level of 400 ft. when legal - for example within the required distance of a tower or structure. DJI mentions its not possible unless you downgrade firmware...really? Also has anyone downgraded firmware successfully to achieve this?
Simply reset the max altitude value in DJI Go 4. It's set by default to 400ft/120m that's all. The flight restrictions are in place only for those who haven't logged back in to DJI Go 4 with their DJI logon. Once you do that it simply sets the locale and flight restrictions to the correct geographic area (ie basically outside of China).
That absolutely was it, apparently you have to be logged in. Thanks again, and Fly Safe!
Reactions: Advexure
Benshy
