- Joined
- Mar 22, 2017
- Messages
- 200
- Reaction score
- 96
- Age
- 59
Looking into purchasing an X5s for my I2 and would like help. I currently use the X4s and am happy with the wide angle cine video, but recently saw some video with an X5s and and Olympus 45mm lens. The depth and smaller view on the shot was amazing.
First, should I purchase the X5s with the stock lens for wider shots and just go for the body and Olympus 45mm and use the X4s for those wider shots. Also, it looks like I need some type of balancing ring if adding the Olympus lens is that correct. I often use ND filters and will probably purchase some polarPro ones for this combo. If adding ND filters is there additional steps for ensuring balance is correct?? Do you still need to use the balancing ring if using ND?
The majority of my current work is for Real Estate but am interested in testing some of the site mapping software out there and don't know if the X5s and narrower lens would provide much benefit over my current x4s
