im loving the lens. Wish on the next update they will enable raw recording with manual lenses with no electronic contacts
Lightweight versionNice, do you have the standard weight or the lightweight version?
I'm not happy with this lens. Looking at your video, you have red circles in the middle of you video. I have the same issue. Look at the middle of you video, you will see a read spot casue by the lens. Also, building are not straight in the video, slanted at an angle. See picture below - Arrow pointing at ring that appers when using this lens only.
So can you just plug this lens in like the others and focus manually to infinity and it works fine - or do you need to hot swap with another lens to "fix" Go 4??
Casey,As to the 'hot-swapping" of lenses, when I tried it, the gimbal growled loudly about it when the Olympus lens came off for me to put the Laowa on. I don't know if rotating the lens with the contacts being on or active is a good idea, or if it will damage the len's electronics that had contacts in it, or maybe the camera itself in doing so? Lot of contact pads on the back of those lenses to rotate the contacts over.
I also read this in the Olympus Pen-F owner's manual. On page 15, this appears TWICE:
• Make sure the camera is turned off when attaching or removing the lens.
Seem the best fix would be for DJI to fix GO so it can be used with non-contact lenses like the Laowa. I also found some odd shift in focus at infinity on the screen when going from Movie mode to Still camera for some reason. To set up the Still camera shot for exposure, I flipped into Movie and set the EV value I wanted there, and then flipped back to Still mode and it held the ISO and shutter speed from the Movie mode. Otherwise, trying to set shutter speed in Still camera mode was maddening. The Laowa doesn't play well with the settings in GO 4, imho.
I need to play some more with this lens. As noted already, flare will be an issue as it is very wide. Perspective angle will cause the tilt to some objects if not 90 degrees to them, but may program can adjust for that. I do see some heavy vignetting wide open, maybe as much as a stop or more in the corners, and adding a filter may exacerbate it too, so that needs to be addressed in post as well. Some programs do better at the vignette correction than others too. LR did pretty well, and they do show some Laowa lenses in it already so the 7.5mm may be coming in a future LR update.
Casey,
Think this would work on the Laowa and allow for it to start up without doing a hot swap?
http://peleng8.com/af-lens-adapters...ip-dandelion-iv-generation-for-micro-4/3.html
Basically a way to chip the lenses yourself
Heck for $28 I'm willing to give it a shot.
ThisThat's a lens flare, all lenses will do that when pointed at the sun
I need to play some more with this lens. As noted already, flare will be an issue as it is very wide. Perspective angle will cause the tilt to some objects if not 90 degrees to them, but may program can adjust for that. I do see some heavy vignetting wide open, maybe as much as a stop or more in the corners, and adding a filter may exacerbate it too, so that needs to be addressed in post as well. Some programs do better at the vignette correction than others too. LR did pretty well, and they do show some Laowa lenses in it already so the 7.5mm may be coming in a future LR update.[/QUOTE
Removing your lens, while the camera is on should not be the solution. The cost of the X5S, is almost 3 times the price of Laowa 7.5mm. They should have address this before shipping.
thanks. I will look into what I need to do for lens flareThat's a lens flare, all lenses will do that when pointed at the sun
footage looks great!Here is my test of lightweight Laowa 7.5 in Brooklyn, NY
