How to make another inspire 1 charger?
Hey, So having one charger totally sucks.
And they gave us a spare cable for charging transmitters with the actual right plug point on the end.
So Im gonna buy a transformer and try make a inspire 1 battery charger by cutting that cable and connecting it to a transformer, Should be easy.
Anyone tried this yet?
Twyford, UK
You should be able to charge the batteries with a normal LiPo charger if it has a Pb program. Mine iCharger 308b can do this and I used it successfully with the P2 batteries.
Whatever you do, you need a 24V charge program or supply for the Inspire batteries.
New Orleans, LA
www.facebook.com
Have you found a transformer/power supply that is similar? I had Googled away and I could not find anything similar
Do a search on the voltages and wattage. I found several suitable power supply's, you just have to be able to find a connector. I also found a few actual OEM DJI power supply's for around $55.00 plus shipping. Not sure what the normal retail is, I didn't check...
patpmcc
