I can't record to dlog when using DNG
Mexico City
www.vimeo.com
hi
I have a problem with Inspire 2 and X7
when I record in dlog, only on the micro SD card does, the file on the SSD card do it correctly if it records but not in dlog.
when I record in proress if I have it correctly it records dlog on both cards. What can be ?
hi
cDNG is RAW. It doesn’t have a gamma or colorspace applied to it yet so it can’t be in dlog. This is the purpose of RAW. It’s just straight linear pixel data that has to be debayered into a colorspace and gamma in your editor.
Log is a workaround to make up for not having raw video. If you have RAW then there’s no need for Log.
But if you really want the RAW video converted to dlog, DJI has a linear_to_dlog LUT you can use in DaVinci Resolve but there’s better log profiles to use.
Why do you want Raw log if I might ask?
Great response... Does it apply to proress format too? Do I need to worry about Dlog or flat video if I just shoot in proress? Can proress also be converted to Dlog?
UrbanScroll
