inspire 1 lightbridge fans and replacement instructions
I have some dc 5v 56w fans for inspire 1 - 10 left at £25 each ( replacement parts ) for the light bridge unit
Typical broken fan issues with collision to nose cone or the upper casing
You will know because the craft will not imu calibrate and will not turn off red solid led light on rear
with new firmware /software it will stop you from flying until fault cleared
The reason it will not calibrate is the resonance given off by the forces emitted by the fan blades being out of balance as its cooling the Lightbridge unit and preventing the imu to reset and calibrate.
If you are interested let me know PM me and ill arrange shipment if I get time before xmas
Real easy fix when you know what you are doing
Also ill give you some tips on how to remove existing fan without damaging the heat shroud on the rear of the Lightbridge unit and fitting new one, including modifications to prevent removing Lightbridge unit if fan breaks again.
good luck all!!
Hi paulhankin are you still selling the fan for the inspire 1 Thanks
abseilerstu
