Inspire 1 Tech Spec for PFAW
Hello,
Just writing my ops manual and wondered if anyone would be kind enough to share the tech specs for the Inspire 1
Attached info I am looking for.
Thanks very much
H
  • Inspire 1 Tech Spec.pdf
Hello,
Thanks very much
H
Please use the search function on the forum - this has been covered many times before.
Here is one example of a thread.
Ops Manual for PFAW - DJI machines
There are many more. :)
You do not need all the info that the CAA ask for since the Inspire is a ready to fly package and some of the information is simply not available.
Your NQE should have covered a lot of this with you (unless of course it was EuroUSC and then they would probably charge extra for it :rolleyes:)
Things like number of engines etc are self explanatory. Thrust you do not need to worry about unless you really want to put in the Max output of the 3510/KV350's which are based on the DJI E800 propulsion system.
MorganDimo
