Inspire 1v2
looking at buy the above I have a iPad Pro wifi only will this work with the inspire
Many thanks
The wifi model does not have builtin GPS. So, if an app want to use GPS it will use an approximate location from a connected hotspot.
Hi looking at buying the inspire 1v2 or pro version the only differences I can see is the camera which is also heavier so less flying time does anybody have any thoughts on this that I can consider
... have any thoughts on this that I can consider
If you are flying with the X5 camera, you should have a TB48 battery installed to get a decent flying time.
Depending on low wind speed and if you do not rush the Inspire to much, you can expect 15-20 min. airtime.
abseilerstu
