- Joined
- Oct 10, 2019
- Messages
- 5
- Reaction score
- 0
- Age
- 57
Which GO4 version are you on? The latest version allows to adjust gimbal not only for roll but also for yaw. It might require many clicks but it can be centered. Once done it will remember the adjustment and will boot up centered every time. Mine for example requires 55 clicks?.Hey! my gimbal points a few degrees to the left and I find no way to center it. I have read that many have had the same problem before but I find no one who solved it. Anyone know what that is due to? Any solution?
It is under gimbal tab - adjustment gimbal - yaw. It is a slow process, just keep clicking every second or so until you are happy with the center position. Do not forget to press "Done" at the end!!Think I find it. I will try now. Post back later... thanks!
Glad it worked out for you. May I ask how many clicks it required?mmarian, that works perfect! Many thanks!
/Hasse
I dident count but it was manyGlad it worked out for you. May I ask how many clicks it required?
