is the A3 the only difference between the 600 and 600 PRO?
There are a few differences. They both use the A3 flight controller, however the M600 Pro includes the 2 extra IMUs and GPSs. This does not change how the copter flies, but provides triple redundancy in case of one of those components failing. Those components resulted in a slightly different cover for the top of the center plate as well.
The Pro also has quick detaching landing gear - making it possible to put it in a smaller case. It comes in a 3 section foam case (not very functional) - but there is a considerable size difference between the M600 and M600 Pro cases made by Go Professional Cases.
The M600 Pro includes a hex battery charger.
The props were also modified slightly increasing the overall lift by about a pound.
I'll double check if I am missing anything when I am back at the office, but thought I would try to give you a quick reply while I had a minute.
Michael
Reactions: DamesNY
