New FW for I2 v01.02.05
I was reading a new post on DJI where the new firmware is showing signs of trouble related to battery. At about 10c they are restricting power and he almost lost the drone.
I was going to upgrade until I saw this. Out winter weather is starting and flight in 10c is required for me.
Release Notes attached.
Date: 2020.09.09
Aircraft Firmware: V01.02.05
Remote Controller Firmware: Ordinary Remote Controller: V01.01.0080 Cendence Remote Controller: V02.00.0190
DJI GO 4 app: iOS V4.3.37 or above, Android V4.3.36 or above
What's New?
  • Added support for Inspire 2 CINESSD 960GB (coming soon).
  • Optimized gimbal to reduce minor roll rotation when aircraft is flying left or right. Make sure to update aircraft and gimbal at the same time.
  • Optimized gimbal to reduce drift when there is no operation or when operation is stopped while aircraft is hovering. Make sure to update aircraft and gimbal at the same time.
  • Optimized power management during flight. Flight power is dynamically adjusted according to the battery temperature and remaining battery power, improving battery usage safety.
  • Fixed occasional issue: battery level displayed in app was higher than actual battery level, which lead to battery level dropping suddenly. Make sure to update all batteries.
Notes
  • This firmware update is important. It fixes a critical issue where battery level suddenly drops during flight due to an inaccurate battery level calculation. Make sure to update immediately.
  • Once firmware has been updated, it cannot be reverted to an earlier version.
  • Inspire 2 CINESSD 960GB can only be used with CINESSD Reader UG2 (coming soon), while the CINESSD Reader UG2 can be used with all Inspire 2 CINESSD.
  • When using Inspire 2 with Zenmuse X4S/X5S/X7, it is recommended to update both at the same time.
  • Make sure both primary and secondary remote controllers are updated to the latest firmware to avoid control errors or camera and gimbal abnormalities.
  • If the firmware update fails, restart aircraft, remote controller, and DJI GO 4 app, then retry
I am updating everything today and have found that the DJI Battery Station does not update TB50's to the latest. I've updated the Battery Station via Assistant, and it still says TARGET FIRMWARE 1.0.0.71
So I'm doing the batteries manually on the I2 (all 16 of them!)
The new CINESSD 960GB that FW release V01.02.050 added support for is now available at Advexure along with the new UG2 CINESSD Station that must be used with the 960GB for offloading. While we don't love the fact that a new station is needed for the new 960GB, we are currently offering the UG2 free with purchase of the 960GB (see promo code on Advexure website for this offer).
Reactions: slim.slamma
nbsgod
