Please let me know Timslapse interval on x4 and x5s
5 seconds with jpeg+raw no ssd (writing to sd only), 1/20 second with ssd.
Camera doenst make a difference, the ssd does. at max resolution
I said that the camera doenst have any effect on the speed, but I have to add that the SSD can only be used with the X5s camera and not with the X4s camera.
My apologies
I understood what you mean. thank you so much :)
Yes, you can record raw stills to the SSD using an X5S, but not jpegs - jpegs get recorded to the microSD.
The RAW DNG photos can only be recorded to the SSD using Burst 20 or infinite burst mode, which then means you've limited control over the frequency, the minimum shutter speed is 1/20th second, and you still need to have a microSD card in the aircraft too.
This is good to know as this infinite burst mode could be used for time lapse? Yes / No ?
myracook
