Check the connections from the lower transforming arms, there have been a few reports of the clamp that goes to the arm slipping and allowing the arm to move, the fix has been to put a washer or two under the clamp screw as it’s bottoming out.
Ill get one up in a bit. Its a few mm of play so ill do my best.No check the clamp on the arm for tightness, it’s the clamp screw that can bottom out, can you do a post a video of the movement ?
