SOLD Inspire 1 - for parts/repair, camera, remote separate
Manchester, NH
www.air-reelz.com
Selling Inspire 1 with camera and remote $1750
Frame only $1000 with DJI factory case
If you are interested in purchasing the camera and/or remote pm me. Camera $450, Remote $500 (still in plastic)
Unit works - missing 2 motors (both melted after becoming jammed)
Video of unit powered on showing motor damage: https://www.dropbox.com/s/vdhlv2zpv5u3d0w/MAH00276.MP4?dl=0
What happened? It will be helpful to know in order to determine what can be salvaged before buying. Does it still transition smoothly? Worm gear straight? Do the othe motors work smoothly? Battery come with it? Why did the motors jam? Cracks in the struts?
Both arms will probably need replacing which is a shame. There are no cracks in the struts or arms as there was no impact of any kind. The problem is that the plastic mount for the motor is actually part of the CF tubing and not the foot. ESCs are probably also damaged. This was not a crash - a fishing line got caught in the props jamming the motors. It was not immediately shut down as we were unaware it had happened.
The landing gear functions fine and is not damaged at all. The other motors will not fire as the inspire gives an ESC status error and will not arm the motors
