..Starting To Get a Feel For The Yaw With The 12mm Olympus..
Spent some time with the X5 12mm today... practising yaw control... starting to get a feel for this lens... its still a touchy lens but its manageable...
Reactions: Scotflieger
nice job....looks like your have 10 battery packs. is it that different from the 15mm DJI. I'm coming from that POS 3dr solo...that was garbage
Yep AJW... i could not have done that smoothly with the 15mm... the 12mm is much nicer to control yaw with....
I do not have the 12mm lens, would you mind elaborating why the 12mm is easier to yaw than the 15mm? Much appreciated
Sure JayBurd... the DJI 15mm has a narrow FOV this makes it sensitive to movement ... the12mm Olympus has a wider FOV which makes it less sensitive... when yawing the more sensitive the lens is the harder it is to get a smooth yaw...
Reactions: JayBurd
