What camera are you running on your
Inspire 2 as that will determine what resolution modes and frame rates will be available to you?
To change your resolution mode or frame rate you will tap on the "Camera Settings" icon which is just underneath the shutter butter on the far right of the screen in GO4. Below is a screenshot of the Video and Photo settings menu.
Ratio: 16:9 is the most universal and a "standard" aspect ratio
FPS: Depending on your selection for resolution, you will have different FPS options. See "Selecting Resolution/Frame Size" below.
SSD vs SD: If you are not using a
CINESSD to shoot ProRes or CDNG you will not need to worry about the SSD area, solely the SD which is where you are making your selections for media that is being written to your Micro SD.
H.264 v H.265 Codec: Simply said, H.265 is a newer video codec that allows for greater compression without effecting quality. H.264 sticks around as not all systems are up to speed with H.265.
Selecting Resolution/Frame Size: In the screenshot below, next to the H264 you will see the resolution. In the screenshot it is set at 4K (3840x2160). You can change your resolution as preferred. Different resolutions have different frame rates (FPS). So, when changing the resolution you will have new FPS options up top. Most common would be 1080p and 60 FPS in H264 with a 16:9 aspect ratio.
This should greatly help to provide a lay of the land in
Inspire 2. Feel free to leave any further questions here. Safe flying!
