90 percent of the flying I do is over water. I've never had an issue and I don't always play the safest either I've filmed wave runners freestyle jet skiers yachts sailboats Wakeboarder Slalom skiers kitesurfers you name it. the two issues I feel like people would have is how the wind would affect the inspire with added surface and also the fact that the gear probably wouldn't be able to make it all the way down in time if the Inspire lost a motor or prop and came down fast. I also push my inspire harder than most I think, so this may not be a problem for others
Yes ,if something suddenly happens,and you have no time to put the landing gear down ,the floats would only work as ,a recovery (preventing the craft from sinking). The floats would be ideal for slow landing in case the battery issue (battery low) and you have no time to make it to the shore.
By what means would you then recover the aircraft after the emergency landing on the water?
I don't know how much detailed answer are you looking for ,but the simplest description would be "SAR"
SAR? Are we to know what that stands for? Can you possibly deliver the said "simplest description"I don't know how much detailed answer are you looking for ,but the simplest description would be "SAR"
How about a system that prevents damage from both rough sea and land landings? Like inflatable balloons on all sides so it will float/bounce no matter which way it falls. Something like the Martian lander.
Boat would be one option
"SAR" stands for " search and rescue"
Aircraft Floats Manufacturing (AFM) was approached by a DJI Inspire 1 owner/operator for the designing and manufacturing of floats. Please see http://www.full-lotus.com
The Full Lotus floats are extremely unique in that they are inflatable. Using similar technology for designing a set of floats for the UAV market is possible.
However, before spending time and resources, I would like to get a feeling on how many present DJI Inspire 1 owner/operators would be interested in buying floats. Cost estimate is about $800.00 and hopefully less.
Advantage of adding floats to a UAV. Land on water, and the floats will add extra shock absorption when landing on hard surfaces.
Also, is there a DJI Inspire 1 owner/operator in the Toronto area willing to test the floats once built by AFM?
Cheers
Matt
[email protected]
One can only imagine how miffed SAR would be when the learned they got called out to "rescue" a RC quad copter.
