Aux power out from I2?
The Inspire 2 top mount is 49g
The Air FPV mount with camera 66g
The Inspire 2 bottom mount 19g (not in photo)
All the mounts have interchangeable components so you can move from I1 to I2 to DIsco to Typhoon to Mavic
Good point. Actually in front of GPS no issues. I have mounted all types of cameras and accessories above the GPS on my Inspire top mounts and only ran into problems with a EVO SS gimbal which was right above GPS module. I isolated that to the gimbal motors causing GPS to go to manual flight mode. GPS can be tricky
can be very dificult to isolate issues. I use the GoPro MAX and Fusion 360 mounted directly above GPS all the time with no issues. I have over 70 of the
Inspire 1 and Inspire 2 top mounts in the field all over the world in the past 2 years and no one has complained. (these do not have the DJI Air FPV on them that I know of) Of course there is always a first time.
Reactions: kronja
Hmm, top mounting rig for Inspire seems rather heavy and big. That aside, I would hesitate to obstruct GPS reception in any way :confused: ...
Good points
Weight is what it is
Size is for changing position, using multiple components I mount such as below: (not designed for Air FPV it is designed to be flexible)
GPS always a concern. I have over 150 flights between my I1 and I2 with only one issue as noted in prior
post.
Thanks for input
Reactions: Killboydotcom
My pleasure!
I've been using the Matek BEC
And FYI, I'm sitting here right now updating my 3d model to allow for tilt on the FPV cam... need to be able to tilt up a little for going forward fast... so you aren't just looking at the ground ;-)
UPDATE:
In my FPV Quads, I've had some issues with Mateks, so I've switched to Pololu BECs, which are more expensive and more bulletproof. Pololu - 5V, 3.2A Step-Down Voltage Regulator D36V28F5
Here is the updated version using nose mount only at 90g with the DJI AFPV camera and components
Curious about the antennas... in my experience those air unit antennas need to be held in place... not only will they flop down, but they will also pop out pretty easily sometimes... Have you not found that?
wdservicesjaipur
