Broken antenna cable in leg
Hello! I have an Inspire 2 that fell and broke both left legs. The antenna cable on both legs was also cut. I ask you, I only found the complete left arm as a spare. I couldn't find that they sell just the antenna cables. Can those parts of the cable where it was cut be soldered? Or I'll have to get the entire left arm so I can repair it.
Depends on your soldering skills. There are two parts to that puzzle. The core wire and the fine mesh wire that surrounds that core. Those two puzzle pieces can not be in contact with each other at all.
To replace that entire cable would depend on whether you can remove it from the system. Once removed, you can probably find a replacement with the help of the Google.
LavernePre
