Replacement left arm - antenna connectors different than original
I recently bought a replacement left arm for my Inspire 2. I needed to replace the antenna cable that runs to the leg as it was damaged when a landing gear leg broke. I couldn't find just the cable, so I had to order a whole new leg. Anyway, I started to replace it this past weekend and noticed that the connectors that attach to the antennas in the legs were different than the stock connectors. It looks like they're the wrong gender. I've attached photos showing the two original connectors and the replacement connectors. I originally questioned if I was sent a right side arm by mistake, but it's definitely the correct arm. Has anybody else seen this or have any suggestions? Is it possible it was produced with the wrong connectors? I'm baffled and any help would be appreciated.
Original left front
Original left rear
Replacement left front
Replacement left rear
Original left front
Original left rear
That’s odd. Is your I2 new or did you buy used? The replacements look like original and oem. Your original connections look very odd and not correct.
Also. Show a pic of the antennas.
Original left front
Original left rear
Hello ..! .. It is very strange that the connectors of the replacement arm do not coincide with the connectors of the original antennas of your Inspire, I suggest you contact the supplier where you bought the replacement and ask him about the antenna connectors perhaps They were badly assembled which would mean making a change in the existing connectors on the arm or changing the existing connectors on the antennas to match the connections. I hope you can find a prompt and favorable solution to your problem ... good luck!
Thank you everybody for your replies. Turns out that when I removed the antennas, a part of the connector from the leg came off and was stuck in the antenna. I contacted the supplier and sent the same photos and they replied letting me know this. I was able to remove the broken pieces from the antennas and they mated up to the new arm without a problem.
LucieChaff
