Buying ProRes & CinemaDNG in dollars in the UK
Hi guys
Im about to buy the two licences for my X5S. Im from the uk and wondered if i can buy it in dollars since it works out £400 cheaper than buy it in the pounds.
Would there be any reason not to buy in US dollars?
Cheers
your correct. even better if you select yuan... as the item is not a delivered item but a simple approval it seam a logical way to go.
Hi guys
Cheers
Please post back here to let us know if it works for you?
it will probably be changed after you have put the SN code into dji.com but try it and post your results, nothing bad can happen (except that it could be a bit more expensive)
Hi guys
Cheers
It will default to your country (or it should) otherwise DJI will fall foul of government imposed taxes (VAT/GST etc)
