Camera yaw by itself!!
Hi Guys,
Although I set the orientation of the camera to be forward always as the drone moves (means no yaw); the camera is still yawing from left to right and never stopped.
Check this video: http://sendvid.com/0agv01cn
It will show you the drone is not flying at all and the camera orientation is set to forward always yet the camera is still yawing..
I opened a support request with DJI Germany and they replied: Please, do the latest firmware update and also the IMU and compass calibration. Please do the gimbal reset procedure. If these do not help, please contact your delaer and ask for a warranty service.
They did not even bother to open the attached image and see that I am already on the latest App and FW versions..
Is this a known issue?! firmware or App?!
Please; help..
Thank you..
You're inside, so I'd expect the compass data to be erratic causing the camera to compensate for movements that are are registered but not actually happening.
Do what they say, calibrate IMU, go to a "normal" flight location and calibrate compass, then calibrate gimbal and check.
jaydenwhite
