Capturing stills while recording video
Arizona
goaerial.media
On the P4P they allowed you to take photos while capturing video. JPG was only supported. I tried that this weekend with the I2 on the latest update and it didn't work. Since I only had one other set of flights on the older app, I don't remember testing it. but I noticed that on the latest version it also no longer worked on the P4P.
Not possible. You have to take sills or video. I constantly switch between the two.
It's quite possible, simply press the photo shutter button while video is being recorded and you'll get a jpeg photo. The Jepg is recorded in the same aspect ration/dimensions as the chosen video mode. If you look above the big red/white record/stop button in DJI Go, you'll see that the icon for switching between video/photo modes changes to another shutter button when video recording is running - you can also press that button to take a still.
As to it not recording a photo, I'm still running DJI Go 4 4.0.8 with the a/c on firmware .0330 (RC .210) and it works for me. If it's not recording a photo, are you sure you're pressing the shutter button - there have been times when I've thought I've taken a still, only to find none has been recorded because I'd accidentally pressed the "pause" button instead of the shutter button :( - it's easy to feel for and get the wrong button on the right hand side of the RC :(
Yep, jpeg only and at the selected video format size/aspect (and shutter/aperture settings). BTW, if you're shooting CinemaDNG RAW, then there's no point taking a photo as you've already got as many DNG's as you'd ever need ;) :D
Yeah, we discussed the CinemaDNG RAW and SSD acquisition a while back with you saying why bother as I am only flying for fun and not money. However, now that Apple will support H.265 in the very near future, I as the same question again. Do you think it is worth it? As a photographer, I do like to get the best still image quality possible. The same with video as I am shooting this a bit more as well.
That's taking the discussion slightly off-topic so if you want to discuss it in depth then start a new topic ( or discuss it under you new iMac topics), but in short, nothing changes as you've already got h.265 enabled/built in - you don't need CinemaDNG for that. Once you've got a Mac with h.265 support, then by all means start using it instead of h.264
I was using the onscreen button. Will try it again next time I am out. Thanks
hukumkaikka
