Charge Inspire 2 controller while in use with a tether system.
We are looking at a tethered setup using an inspire 2 for hours long aerial ops. With the possibility of running for hours will either on the controllers charge or run while plugged into a power source?
Just want to be able to Maintain in the air with the controller plugged into a monitor. Or use screen share with an iPad and Apple TV.
The standard RC will work while charging, the Cendence has a hot swap battery so you can change it, although if you’re live streaming it would still cause an interruption. Never tried plugging the Cendence in whilst flying.
There is a cable that is used to charge a remote from a TB50 battery, it works with both the standard and Cendence controllers.
Smithtelyis
