dji inspire data recorder error
hi efstathios greece
I have inspare 1
lease help I'm getting a data recorder error where it should say safe to fly.
Drone works and flys perfectly apart from this error message.
Also Windows is unable to format the internal flight recorder sd car
please help to clear all data from the flight log.
for 10 days passed my guarantee and dji I asked to send it in for repair.
thank you
I have inspare 1
thank you
This sometimes happens after a crash or very heavy landing - have you had either?
You will need to strip down your Inspire and get access to the internal SD card which records the flight data. If you are not comfortable stripping down your own aircraft it would be wise to send it in.
no crash or very heavy landing, after firmware update. I make everything I have not problem
where is it in ispire internal SD card ? is it integrated into BOARD?
Hi I have this issue also no crashes or bad landings ,if I gain access to the internal sd card what do I do next
Rick
Please open the main unit and check the SD CARD is good or bad.
I attain the same problem for P4P then I had replace the SD card then it’s work fine.
jbdigit
