Flir xt2 vs Mylar space blanket
Very interesting. The Military just signed a large contract with a company to create a cover for ground crew to have a similar impact. I am interested to see what the opposite side of the blanket would look like. I am assuming that they are not the same material
OK, so I watched the video again and at the end you can clearly see the back side of the cover, however it is the same as the front. My guess is because Aluminium Mylar has an emissivity of .044. Correct me if I'm wrong Thermographers.
I am not a thermographer, but my understanding is that this material has such low emissivity it essentially reflects the thermal radiation of the surrounding environment, much like a mirror.
What’s the opposite of emissivity? Reflectivity?
The mylar is the same on both sides. While it blocks IR or thermal transfer through the material from the warm body target, it also reflects on the other side the surrounding IR and further eliminate any IR detection from that covered target. Just as you could shield the same body behind glass, it just does not pass IR.
ziamedicalcenter
