Gimbal issue
I just updated 2 Inspire1 Pro aircraft to 1.09.01.30.
Now with 3 of my X5 Gimbals and both Inspire1 aircraft and 2 separate RC's, I have no horizontal gimbal control. Vertical is fine and I can get horizontal movement with my finger tracking on the tablet screen, but the Gimbal Mode toggle does not do anything. I set the gimbal toggle mode to both C1 and C2 and tested on each RC, but still no "toggle" to horizontal mode with either setting. So no horizontal movement with roller button at all. Of course I have calibrated controls and booted/rebooted many times.
I have used all combinations of my AC's and gimbals to no avail. I have the RC's in Master mode, and have not tried working as in Slave mode yet. Will do that this evening.
The other C1/C2 modes seem to work okay, like return to forward position, etc.
Has anyone else encountered this? Is there something obvious that I am missing?
I had it happen once. The fix was to change the C1 function to a different setting. Then reboot. Then change it back to horizontal. But it sounds like you have already tried this. Are all pins clean and none bent on gimbal mount?
abseilerstu
