Gimbal Yaw Drift
Hey,
does someone also have a yaw drift with the gimbal. After a rotation of the Inspire the gimbal won't hold it's orientation and instead begins to drift left or right for a few seconds and the stops and stands still.
Do you have some ideas how to fix that?
Hey,
It can't be fixed - it is an inherent feature of the PID tuning and the gimbal reacting to its Deadzone' of around +/- 5 degrees of centre.
You can try turning off Gimbal Synchronous Follow in the app which will stop the gimbal reacting to the stick inputs pre-empting the aircraft yaw.
I just was wondering because I don't see that drift in videos of other Inspire Owners. It even happens when I just turn the Inspire by hand on the ground. But it seems reasonable with a Deadline of 5 degrees.
Thank you!
byyshapeup
