Gimbal yaw mode for shooting panos?
UK
Can anyone recommend an app for shooting panos which has the option of gimbal yaw rather than aircraft yaw?
You can set the button under your control to switch the camera tilt wheel to camera pan. Hit the switch and the wheel controls pan, hit the switch again and the wheel goes back to tilt.
Or, if you fly in atti mode and start flying in a certain direction, you will continue in that direction, then use the GO App you can control the camera by touching the screen and moving your finger around, so you can control pan AND tilt at the same time. You just have to touch and hold the screen for 1 or 2 seconds to get into that mode.
