GL658c charging problem > help please
I’m a new member. I’ve own my inspire1 v2.0 since 2019. I’ve ran into my first problem with it and realized that there is a community of fellow inspire1 pilots out there that could be a real source of information and help even at times above what DJI could offer.
My GL658c controller shows one green light, when I hook the DJI charger to it, the lights blink in normal order as always, but the controller want charge pass the one green light.
I tested the controller by flying the drone, it worked fine.
Would I fully de-charge it and try to recharge it to see if that will work?
Finally, what is my odds of a new battery for the controller fixing the problem?
Thank you!
Flash
You need to open it up and check the battery voltage with a meter. I believe it is a 2 cell Lithium-ion battery, so when fully charged you should get 8 to 8.5 volts. If below, replace the battery.
Reactions: Donnie Frank
Charger works good. Got it charging to a full charge again after near fully de-charging it. Not sure why, but it’s fully charging now.
Thanks,
Flash
