Hi all, i've been trying to complete a job that requires flying towards a sign on a building. The flight starts from approx 40 metres high and 40 metres distance from the sign and going down to 5 metres high where it stops at around 2 metres from the sign. So quite a steep descent needing the camera to be pointing at the sign throughout the shot.
I've tried doing this flying manually but can't seem to get it quite right. Reversing the shot would be the easier option but I have someone walking into the building and they would have to walk backwards for this to work. Has anyone had any experience of using Litchi to perfect this type of shot? I've pre-planned the mission on Litchi but i'm concerned that the Inspire will not stop 2 metres from the sign.(I also have to fly over some 10 to 15 metre high trees on the way in). I know GPS accuracy can vary for a whole load of reasons so to mitigate this slightly, would using a Bad Elf pro 2200 instead of the iPad pro GPS improve the accuracy of my planned mission? By the way the location is not somewhere i can pop back and forth to very easily for trial and error testing.
Many thanks if you can help with some advice on this.
Jon
Jon
