GPS static position accuracy
UK
Just wondered if there's a way to improve the static/hovering GPS accuracy?
I had 18 sats today, but while attempting a pano with DronePan (yawing the craft) I found I had a HUGE amount of drift, rendering the images useless for an accurate stitch.
Don't seem to have this problem with the P4 though.
I imagine the I1 can't use the vision poisitioning system during yaw, but the P4 with newer tech can.
But with an Inspire you'd rather want to pan the camera instead of the craft and the problem wouldn't appear.
See my post "crosswind drift".... I am having the same issue I think.
Increased the brake to 110, but no luck unfortunately. Was out on a job today and tried a pano with the Inspire. First yaw was ok, but second yaw was accompanied by a 10 metre drift to one side.
Ended up using the Phantom 4 instead. Not ideal conditions as there was a good breeze, but it pretty much stayed put during yaws.
If anyone has any more thoughts on 'fixing' the Inspire issue, I'm all ears.
Reactions: andrew259
VanitaYaga
